Sony Bravia KD 50E3000 TV will not turn on. It flashes green 63 times then flashes red non stop. I counted 200 times and then I stopped counting. I unplugged for more than a minute and still does same thing. Thanks for your help.
Sounds like it needs a new power supply board.
Here's one: http://www.shopjimmy.com/sony-a-1310-234-a-be-board.htm $69.32 USD
Easy to replace, just open the TV up, unplug and unscrew the old one, pop in the new one!
SOURCE: How to undo safe mode
This isn't safe mode, what you see is the result of a failing component inside your tv going bad and sending the power source in the protected mode.
The tv must be opened and tested to identify and replace the defective part. This is a job that should be left to a professional repairman, if you don't know exactly what you're doing you could mess it even further.
SOURCE: MY SONY BRAVIA HAS THE
Have you checked your connections to ensure that everything is properly connected from your TV to your cable or dish box?
Have you tested your TV on multiple types of media. ie, DVD player, game system, live TV? Do you get the same problem with every type of media?
If your TV only has problems playing live TV it may be a problem with your service provider's equipment, if the error occurs with multiple media types then I suggest you contact Sony and inquire as to getting your TV replaced.
