Question about Samsung WB250F SMART Digital Camera Basic Kit
Samsung wb250f says "connecting to computer" and thats it when I turn it on
Also when I plug it into the computer it will not recognize the drive
    Sergeant:
  • 179 Answers
Its a camera and as with all cameras we assume you have followed the rules. the rules are with the camera off, plug in the cable to both devices. then with the pc on already, then switch on the camera. if that is what you are doing then it should work ok. if it does not then it implies the usb port you are plugging it into has some old style Sniffer program looking for a different sort of usb device that will only work when plugged into that particular socket, thus preventing anything else from working properly in that socket. turn the camera off and try plugging it in to a different USB socket.
Posted on May 22, 2019
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 29 Answers
SOURCE: Connecting samsung U600 to my mac computer
mine wouldnt work because the samsung mobile pc software wasnt compatible with windows vista, so if you have vista, it wont work either, will only work on windows xp x
Posted on May 07, 2009
The screen is black when i turn on my samsung WB250f after i tried to update the software on it
Please contact Samsung support on this, there may be a fix for the glitch.
Jan 24, 2017 | Samsung Cell Phones
How do i transfer pictures from camera to computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Sep 16, 2014 | Samsung Cameras
I have a samsung PL120 camera. It is not recognized in the computer.
Sir, go to this page and download the software
http://www.driverowl.com/p/Samsung/PL120/Driver/108005
Mar 17, 2014 | Samsung PL120 Digital Camera
My computer no longer recognizes my Samsung L830 camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jul 06, 2013 | Samsung Digimax L830 Digital Camera
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
Plug my camera into the usb port, computer doesnt recognize it
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 25, 2009 | Samsung S860 Digital Camera
Does not recognize camera plugged in to usb
Jul 17, 2009 | Samsung S860 Digital Camera
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Samsung WB250F SMART Digital Camera Basic Kit Logo
161 people viewed this question
Top Samsung Photography Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Samsung Photography Expert? Answer questions, earn points and help others
