Cameras Logo
J
Jan Courts Posted on Jul 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kodak digital camera and I had it in my backpack bag with a icepack .
My camera was expose to moisture from a icepack I had in my backpack with the camera and now I can't get the camera to work.
Harrie
Level 3:
Top Expert:
  • Kodak Master 6,746 Answers
  • Posted on Jul 26, 2014
 Harrie
Kodak Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285548
Points
83153
If the icepack caused condense in the camera, the moist can have damaged the electronics.
Try drying it in a bag of rice and before you continue, charge the battery. If it does not work, start saving for a new camera. Sorry.
2answers
Have a Canon Rebel EOS T5 with a Err 70. Have turned off and taken the battery out, still get the same message. Any help to fix? Thanks!
the camera probably was exposed to moisture, could be a mother board problem, need to have it replace
Lens stuck on zoom, and rattle
sure your machine has been exposed to sand and moisture, so this all stuck and short circuit, take it to a technician but I would advise discard
My Kodak EasyShare 643 photo is over exposed
These are great compact cameras. check out http://www.teleplancamerarepair.com/Kodak_EasyShare_C643_Zoom for a quote on fixing it.
overexposure generally has to do with internal mechanism. If you have been really hard on the camera or had it bouncing around in a bag or other might have dislodged something. Do not force the lens in and out for that will make matters worse. If you decide to try and take it apart beware of the little tape looking things, those are what hold all the pieces together inside and are practically impossible to replace without the correct tools and expertise.
Lumix DMC-ZR1 / DMC-ZX1 Digital Camera: My lumix dmc-zx1 got wet with normal sweet water t...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to take out all moisture trapped in the camera. You could do this: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
2answers
Camera affected by water now no switch on
water is bad for cameras you can get a new camera just like the one you have now for under $15 on ebay!! :)
Kodak C643 digital camera
Yes, that could cause problems.
I would suggest to sell it on Ebay or some such site for parts or repair, as is.
To fix this one is not worth it, in my opinion.
3answers
Kodak Easy Share z712 IS
nothing is going to repair this Damp and moisture is death to digicams But the next camera, and if you like taking photos in the rain invest in a water proof enclosure.
Camera won't turn on
You were camping Huh! In a Tent My guess Damp Damp is the death of digital cameras. Take batteries out. Find a large poly bag- preferably with a snap lock zip type thing- Get hold of some of those little sachets of Silica Gel Or a cloth bag and fill with rice and salt. This will absortb moisture. Pull all in the poly bag somewhere gently warmf or a couple of days. Do Not turn the camera on.
I kinda got sticky stuff one my wheel
You can take it to a store to send it out for repair but the labour on this could be pricy. You may want to get a quote at least. I am NOT suggesting you should take it apart yourself, and I'm NOT telling you this is safe according to Kodak, but sometimes you can use a few drops (very little) of isopropyl alcohol (only) to help as it is 99% pure, will not cause rust, and evaporates very quickly. You can get it at any drugstore for a couple of dollars. Basicly work the button and wheel again and again with the alcohol. Make sure that you allow evaporation before turning the camera back on.
Lens Error
Hard choices here my friend. Sand in the lens system is bad news.
Jams up the close fitting bits. You basically have two choices. Get the camera repaired or throw it away and buy a new one.
Cost of repair will likely exceed the value of the camera. Perhaps not, but it's a gamble. Generally, just to get the extent of the damage evaluated and an estimate on repairs will cost you many dollars.
Alternatively, IF you are very handy, patient, observant, and have the correct tool, you MIGHT be able to dismantle things enough to do the cleaning yourself, but likely not to work. IF you got some salt contamination in the camera, which can be from just spray and related moisture, delicate electronic parts will be corroded and needing replacement.
Have fun ;' >
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
