Question about Sony KDF-E60A20 60 in. LCD HDTV
How to install cable card - Sony KDF-E60A20 60 in. LCD HDTV
    Top Expert:
  • Sony Master
  • 76,204 Answers
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jul 27, 2014
6ya staff
SOURCE:
Hitachi rear projection hd tv. message on screen says invalid cable card installed. remove to restore video access. there is no cable card installed as we have cable service through a cable company. j
Two things to try here---first is unplug the set for a while and plug back to see if the microprocessor in the set will reboot.
Second look to see if slot for the card has anything at all in it or is dirty.
if dirty blow it clean and repeat unplug procedure Note: very few of these sets have a hard reset feature but if all else fails call Hitachi customer service with the model number---they have some very good people answering the phones and an extensive data base on sets/problems.
Apr 11, 2012 | Hitachi 57F500 57" Rear Projection...
How do i install my ati x1900 video card on my mac pro
That card needs extra power - more than it can get thru the PCI-E socket - so do exactly what it's said : connect an extra power cable from the power source to the card.
Feb 22, 2010 | Apple ATI RADEON X1900 XT Graphics Upgrade...
Replaced video card. Now sysyem won't turn on.
Did you connect you monitor cable to the new installed video card. You need to connect you monitor cable to the new installed video card. You need also to installed the CD driver of your video card.
Jan 23, 2010 | HP Compaq Presario SR1620NX...
My desktop gateway 3 series does not have a video card.....I would like to add one....is it hard to do so ??I want to buy a geforce 9600 or greater...
It is not so difficult as it seems to be.
First ensure that your computer meets the system requirement for installing a particular Video Card. You can get these details on the box of that card.
Once you are ready with all the details and the compatible card, follow the instructions as under:
  1. Turn off your computer and disconnect the power chord
  2. Open the Cover of your computer Tower.
  3. Disconnect the monitor cable from the Onboard VGA
  4. Locate the compatible card slot.
  5. GEForce 9600 would require a pci express slot
  6. Match the notch on the card with the Card slot and insert the card with a slight push.
  7. Fix the card to cabinet with a screw on top
  8. Connect the Monitor cable to the newly installed Video card
  9. Close the cover
  10. Connect the Power cable
  11. Restart the computer
  12. Your operating system will detect the new Video card and prompt you for drivers
  13. Installed the necessary drivers from the CD provided with the Video card
  14. Finish the installation and reboot the system
That's it you have a new Video card installed !!
Please let me know if you need any further help in regards to this.
Thank you for choosing Fixya
Oct 12, 2009 | Gateway GT5220 PC Desktop
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
What do TV cards do when installed in computers
TV cards fit into PCI or PCIe slots depending on the bus speed of the card and the motherboard. TV cards provides a port for CAT-V cables. With TV cards, you can watch local TV stations and or cable TVs in your PC. Connection is through a CAT-V cable.
Jul 26, 2009 | Computers & Internet
I have just installed a crucial x1600 pro graphics card,when i fired up the computor the monitor displayed multi coloured vertical lines and a box appeared saying it was in analog mode, how do i configure...
change cables on card you should have two ports on the card one for analog and one for digital and the cables are different check the ends of the cables digital and analog are different configuration.
Dec 31, 2008 | Computers & Internet
Problem
just check whether u r windows XP service pack 2 is installed or not
later on uninstall all sound card drivers in the device manager and reboot the machine then it should detect u r sound card then install drivers and plz unplug the cables behind sound card after u install sound card drivers u plug the speaker cable to green colour wave out of the sound card
Aug 01, 2008 | Microsoft Windows XP Professional With...
Lost AV cable in a move
Radio Shack have all sorts of cables.
E-mail Voodoo3 technical support for a cables
Try a cheap PCI VGA card on your PC , then instal the AV after it; it might not stand alone.
Good luck
Feb 04, 2008 | 3dfx Voodoo3 3500 TV (16 MB) Graphic Card
Output problem for Hollywood Plus
http://www.sigmadesigns.com/public/Support/pdf_files/user%20guides/hwp_man.pdf This is the User's Guide to install. A google search also turns up drivers for this device - you might want to download those first. And it appears there is a specific manner in which to install and cable this card. Since it is a used card it is possible that the card is bad. Did you connect S-Video from the card to S-Video on the TV, or did you get the S-Video to Composite cable converter? Apparently brand new it comes with the converter cable.
Dec 14, 2006 | Sigma Design REALmagic Hollywood Plus...
Sony KDF-E60A20 60 in. LCD HDTV Logo
18 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
