3 blinks then 4 blinks
The fault code is '34'.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
SOURCE: what is 34 Tuner 1...my Mitsubishi wd 60737 is
It will be best for you to contact the service center for Mitsubishi.
Testimonial: "I think I made a mistake in diagnosing it...it flashes a total of 7 times which means it is the 8v6 power supply...would I still need to contact the servicing center or is this something that I can fix myself."
