Control panel not responding
SOURCE: Whirlpool Duet Washer
Push end of cycle signal button(it's the last button on the far right)
SOURCE: Duet Washer Control Locked
I need some more info.. when you say locked up do you have a dispay or is it blank?
SOURCE: control panel locked on my whirlpool duet washer
Hold the end of cycle signal for 3- 5 seconds.
SOURCE: Washer control panel flashing and won't restart
I don't know if this is a real solution but it wokred for me. I just unplugged it for about 10 minutes and then plugged it back in. The flashing stopped and I was then able to resume normal function.
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however;
your whirlpool duet washer needs a reset to resolve the control lock problem.
Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset
the control. Please get back to me if you have any other questions.
Kevin
