Question about Maytag Neptune FAV6800AW Top Load Washer
My pump went out on my Maytag washer. Put a pump on it, now it seems to be out of balance. how do i fix it?
Out of balance switch will not stop washer when load becomes out of balance.
Your switch is bad. You don't necessarily need the switch. Snip the wires off either side of the switch and fuse them together with a wire connector.
May 06, 2012 | Maytag Atlantis MAV6000 Top Load Washer
How to fix a errow ob on maytag washing machine
OB is an out of balance load error, try re-distributing the clothing and see if it helps, also make sure the machine is level, if this doesn't help there may be a fault with the out of balance switch or lever.
Mar 06, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Nov 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Same balance problem as ghouse has with his Maytag
We are discussing at least three issues, one a drain issue and two is a pressure switch that I would replace before I try to reset it. Three possibly a clogged pump.
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
