I purchased a remote for my GE television. None of the codes listed work for my TV. I tried to program it automatically and when I pressed the "SET" and "POWER" button at the same time and held for 5 seconds, the light flashes and the TV turns off. I pressed "any" button to stop the auto search and pressed the "off/on", volume, channel buttons, but nothing works. I just have a blank screen.
I need any assistance you can offer.
Thanks,
Universal remote allow you to control multiple
electronic devices with a single remote. You can use the remote to work
your TV,DVD player, cable boxes and other devices from the comfort of
couch.Philips is a popular manufacturer of universal remotes.to program a
GE remote for SONY TV,you will either need to input the device
code or perform a code search
direct entry
first.turn on your TV manually. next.press down
and hold set-up on the remote.the red indicator light will stay
lit.after that.press the TV device button to let the remote know you
wish to program a television then.enter your device four digit codes on
the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the
number zero in the beginning of the codes finally.test the remote to
ensure it works.with the turned on,press the channel button and see if
the TV responds..if it is work the remote programmed and you are done,if
it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
need code numbers for a g e remote
Picked up my Harmony 550 today, and all I have is a blank screen. Changed batteries, but no luck. Any suggestions?
i have a 19 inch superscan, bought a tvtech universal remote 3 i have it on autosearch for 2 hrs no code yet. no code listed for superscan in the book. who makes superscan tvs and tvtech remotes.
new batteries,
TVtech Universal---does not work?
Remote was set to auto program. Turned the TV on/off and that was it. Now it will not allow me to do anything, no rest, change channels, volume nothing , HELP
