I can turn the tv on from the side of the tv and control the volume on the side of the tv.
I'll help if I can, but I have questions:
Do any of the other remote functions work (either remote)?
Did the original remote work before you obtained the cable remote?
How did you mate the cable remote to the TV?
Have you googled this issue? If so, were there any common themes?
Hi, we had that problem the first two days we purchased our set. Fortunately they replaced it with no problem. I hope you purchased an extended warranty, Coby is out of business but warranties are still being honored...I don't know of a fix for this..Basically the Coby is a dud..I wish you the best! let us know how it turns out..
Herb
SOURCE: remote control
I have the same issue, and Coby told me that there are not codes with the remote so a unaversal one will not work. They sent me a new remote and 2 months later it worked for crap. So I get up and walk to the TV now.
SOURCE: Hi I have a brand
The codes that was in ur universal remote manual don't work,useally there are no more codes out there will.Try website like Remotes.com to buy an original remote.
SOURCE: Cannot increase the volume on Coby TV
Your tv is on 100 but it sounds like its only on 50. There is a solution is go to the menu then go to sound and then turn balAnce all the way down
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
