Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Jul 27, 2014
My bottom mount french door refrigerator, the upper part does not cold, it's warm
John Wright
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jul 28, 2014
John Wright
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
18974
Points
25
Sorry your having trouble so soon!
First thing you need to check is inside the freezer section.
The freezer fan, the fan is W10128551 and should be running
along with the main compressor. Since the freezer is working,
I would check the food on the top drawer or on the freezer door shelf.
They too might be soft..without the fan.
I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really
a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time..
John Wright
4 Related Answers
Anonymous
  • 400 Answers
  • Posted on Mar 06, 2009
SOURCE: Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Anonymous
  • Posted on Jul 07, 2009
SOURCE: Icemaker does not make ice
Sometimes an icecube gets caught up in the tray causing a 'rattling' noise when it tries to operate and also causing it to not produce ice. Lift up the lid, take out the wedged ice cube and it should start to work again.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Oct 19, 2012
SOURCE: refrigerator too cold
The model number you posted is for a range. Please check the number again and re-post.
  • 19187 Answers
  • Posted on Jan 20, 2014
SOURCE: Maytag French door refrigerator not cooling refrigerator.
There is a defrost coil and timer to control it, you will have to check those to see if they work, If you are unplugging it to defrost it would take hours to clear the ice.
Testimonial: "Thank you Brad - replaced the fan and cool frig!!!"
My refrigerator is warm and freezer is ok how do i repair or adjest my refrigerator
Check the fan in the back at the bottom it may be blocked with pet hair or dust just vacumm
1helpful
Two year old Fridge with bottom freezer and french door upper. Cold freezer and a warm fridge how can we correct this?
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
1helpful
My freezer on the french door model is freezing over. All of my food has what appears to be snow. Why
warm air is somehow leaking into the freezer or a common problem with bottom mount doors is they get left open and that's what happens,check the gasket or the door was left open.
I HAVE A Maytag MFD2560HES Bottom Freezer French Door Refrigerator THAT IS WARM TOP AND BOTTOM
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Maytag bottom mount freezer (top) icemaker not working
check to make sure that your fill tube is not blocked with frozen water.
if there is no restriction then you have a faulty ice maker.
Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
1helpful
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Refrigerator is not cold but freezer is still operating.
Couple things, both doing with air flow. If the fan in the lower freezer isn't working there will be no cold air moved into the upper fridge. If the defrost cycle happens to be dead then the coils down there will freeze solid and there can be no air flow over them to cool the upper area. You'll have to pull the lower drawer out and take off the interior rear panel to check these things. Hopefully it's just that the fan motor went out. It's real easy to change. Let me know what you find, if the coil is all iced up solid then there's more things you need to look into.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
