Genuine and consistent random flashing is normally a cable fault if is the main VU graph but there are other symptoms as well. If is the O/l (Clip) or Solo Leds on a channel strip have you checked for earth loops etc? Does it do it all the time or only when there's a signal? Which Leds are flashing and is there anything else that is not behaving correctly? It would seem if you can get a repair shop to have a look this would be your best bet.
SOURCE: Model: Mackie DFX-6 Hi, I have a
Check the power going to the main output with a multimeter. It may be a simple fuse or the output board may have come disconnected from the main board.
