Washing Machines Logo
A
Anonymous Posted on Jul 27, 2014
Water sits in the pull out soap/bleach drawer?
kev bush
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Nov 18, 2015
kev bush
Expert
Level 2:
New Friend:
Answers
90
Questions
0
Helped
26869
Points
234
Ur using to much powder.remove drawer from machine and clean away all the excess gunk
5 Related Answers
Anonymous
  • 1665 Answers
  • Posted on Feb 15, 2008
SOURCE: detergent dispenser stuck, I think the detergent cup is preventing the drawer from opening
Here there is a user guide and instructions of a similar washer model.
http://www.laundrymanuals.com/manuals/mfg/lg/wm2496h.html
and also all available LG washer manuals to download.
http://www.laundrymanuals.com/manuals/mfg/lg/lg_frontload_washer_product_list.html
Have a look of how top lid is mounted.
Anonymous
  • 639 Answers
  • Posted on Aug 26, 2008
SOURCE: soap dispenser drawer jammed
Dear SK8RMOM,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Anonymous
  • 15 Answers
  • Posted on Apr 12, 2010
SOURCE: water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Anonymous
  • Posted on Sep 19, 2010
SOURCE: soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
Anonymous
  • 4323 Answers
  • Posted on Jan 27, 2011
SOURCE: LG TROMM WM2277HW Problem:
Hi
Try and disassemble the dispenser & check the wiring to the dispenser housing--
1. Disassemble the top plate assembly(Unscrew 2 screws on the back of the top plate).
2. Pull out the drawer.
3. Push out the DISPENSER ASSEMBLY after unscrew 2 screws.
4. Unscrew the nut at the lower part of the dispenser.
5. Disassemble the 4 connectors from the valves--
Wire Color
Blue Housing (OR-BK)
White Housing (WH-BK)
Blue Housing (GY-BK)
Red Housing (BL-BK)
6. Unscrew 2 screws from the back of the cabinet.
Hope this helps... Please post back if you need more information.
Daniel
2answers
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Mould in water inlet assembly how to remove this assembly for cleaning. the fabric softner try never gets drained. Has a three valve inlet sysrem.
Pull the dispenser drawer out until it stops then push down the release tab and pull the drawer out completely. Separate the parts then immerse it in hot water with bleach and give it good a scrub with an old toothbrush.
The dispenser drawer cavity does not need to be removed for cleaning. Otherwise, you have to remove the top panel, console, toe panel, and the front panel. Removal of the front panel requires the removal of the door lock/switch assembly and the boot be separated completely from the front panel opening. Use hot water to loosen the mold then spray it with household cleaner with bleach. Let it sit for a couple minutes before starting to scrub the molds off.
1helpful
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
Maytag MAH8700AWW - detergent drawer full of water
try removing the drawer to see if one of your kids has put something in there
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Bleach and softener dispensers filled with water at end of cycle
what u need to do is take the soap drawer out totally u need to put under the hot tap pull the containers out of the soap drawer and clean out everywhere what happens is the containers have small slits underneath them and when these get blocked it doesnt let the water run out using hot water and a brush to clean everywhere will sort this problem out this is a problem for all washers
2helpful
2answers
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
13helpful
5answers
Water in soap holder after washing.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
