Hi, i have Candy ctf 1005 washing machine and i dont know how to open filter, i think he is stuck or something. machine doesnt work until i clean this. what to do? thx
SOURCE: Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
SOURCE: wont spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
It
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: could you tell me why my candy go 482 washing
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
SOURCE: Hi i have candy go washing machine it shows error
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudimentary understanding of the mechanics of a washing machine.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
