OUTPUT AV2 WORKS BECAUSE I HAVE MY WII PLUGGED IN TO IT. MY SDMI 2 ALSO WORKS BUT NOT THE TV. DO YOU HAVE ANY SUGGESTIONS?
Contact the authorized service center. Your TV need a through checkup.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
SOURCE: Turn on Samsung LN-T4665F and vertical colored
when I turn the modelLN-T4661F TV on it just clicks and clicks any help how to fix it.
SOURCE: LN-R408D Samsung LCD flat screen TV
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
SOURCE: Slow to show picture after turning tv on. Takes
Look for bad caps (leaking/bulging top) in the power supply module. Make sure to replace them with good quality caps such as PANASONIC FM/FC series.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: TV TAKES A LONG TIME TO TURN ON
The tv power supply board have those dead parts call capacitors,they alway have capacitors leakages of gases,bulges ups on it tops or puff up on it tops.These capacitors are having leaking gases and dying reqiure changing,u know basic's electronic and soldering.Replaced these dying capacitors soon to dead capacitors,ur tv will power up normally and work quickly.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
