It is on german and i can't get it back to english
SOURCE: language problem
I would go to menu and setup. Setup is most likely near the top but even if it isn't, keep going into the various folders until you can scroll through languages. Each language will be written in it's invidividual language (Chinese, Japanese, English are all obvious). Your instruction manual might show you the order of the lineup of the setup screen. This way you won't have to be able to read German to find English.
SOURCE: just bought a coolpix, was
usually : go to setup > search for language > select : English > press OK or Set .
If this doesn't work reset the camera to default settings and set it up as you would like it to be
SOURCE: Need to change from German to English
Menu, Cam settings (Logo= wrench), language Settings (Logo=ABC)
And you no longer need a nite language course :)
SOURCE: How do I change language from Spanish to English
Press menu and select Configuración and then select idioma and then select Inglés and you should be back to English!
There is also an extended user guide available for your camera on the below link!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00964/C160_C180_xUG_GLB_en.pdf
cheers!
SOURCE: how do I change the language back to english on
Press the MENU button. Use cursor-left/right to select the Setup tab. Use cursor-up/down to select the sixth item.
Here's the page from the user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg01133/urg01133c5s1.shtml
