Question about Ricoh Aficio Office Equipment & Supplies
C821 sc 548 reset
Fuser
4 Suggested Answers
6ya staff
SOURCE:
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Savin SC548
Fusing installation error Fusing unit set error.
Turn the copier off.  Remove the fuser unit out of the machine by removing the screw out next to the blue knob and pull it out by the blue know.  Inspect it for wear and tear.  If anything looks worn out it should be replaced.  Reinsert the fusing unit back into the machine.  Secure it with the screw and turn the power on.
Posted on Sep 21, 2008
SOURCE: code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Posted on Aug 09, 2009
Bernard D'Souza
  • 163 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
How do I fix error code sc 548?
The machine cannot detect the fusing unit when the front cover and right cover are closed.
Possible causes:
Check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of position. SC 548 usually happens when a paper jam occurs and user does not properly fit the fuser back in place
The fuser may also not be fiitted properly due to some foreign object in between fusing belt and the sensor
From the panel, enter SP 5810 (SC code reset), select "Execute", select "close", exit SP mode then turn main power switch off, wait 30 seconds, the turn it back on.
To enter SP mode, press the yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button. from the menu select copier SP then type in 5801 and press # select execute then power off and back on. Your machine should now be working.
Hope this helps.
Sep 04, 2014 | Savin Office Equipment & Supplies
Sc 548 gestetner 2712
this proplem mean fuser heater unit is not pack correctly in his place unpack and put it again in his place but befor do that make reset cancel yellow 107 and hold on cancel red 6 times and close machine and open if still apeare unpluge fuser unit and plug it and do reset again please vot
Mar 30, 2011 | Gestetner Office Equipment & Supplies
It appears codes SC 548, 541 and 546, and key tool machine does not function
are yo try to go to sp mode and reset if it not work out yo must change thermistor in fuser unit
Jan 11, 2011 | Ricoh Aficio 1035 Copier
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Code shows SC 548 how do I clear this
are closed.
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
I have a Savin 9955DP/9965DP copier with a funtional service code SC548-00 is there anything i can do to fix the problem?
The SC 548 error usually occcurs in the fuser section when it ahas been reset incorrectly the drive and gears are not locking properly or the sensor has not registered the fuser correctly I would look in these areas check the seating of the fuser you can reset this in the modes with 5-810 sc reset then turn off.
Jun 24, 2009 | Ricoh Aficio 450 Copier
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh 1027 but it does work codes sc 548
You have a problem with your fuser - either an overheat, or lack of heat. Can only be reset by technician in a service mode, once it is fixed
Feb 19, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
41 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
