I left the battery in the charger for approximately 24 hours.
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
