SOURCE: My chainsaw, after runnig ok
it sounds like a fuel issue. on my Stihl (390 )saw I had that same problem and I found that the fuel line inside the fuel tank was kinked and split and sucking air ( not fuel ). also check to make sure your gas oil mix is correct ( start fresh when in doubt ). it also can be a idle issue ( Fast idle or Slow idle ), but since you just had it serviced - I would look at the fuel line and fuel first. please let me know what you find and if that does or does not solve your problem,, there are a few more things to check. ( also - check to see if the air filter is clean and clear ,, brush it off if dirty ).
c...
