Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
How to remove large fan - Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Get a the fan off a 1997 expedition
should be 4 bolts and ya prolly need fan clutch toolmto loosen part of fan
Nov 10, 2012 | Cars & Trucks
HOW TO REPLACE CLUTCH FAN
to remove clutch fan you need to remove upper fan shroud, you need large wrench to remove the fan clutch retaining nut to remove fan and clutch away from the engine drive belt should keep pulley from turning while loosen fan clutch retaining nut.if pulley belt turns while loosen fan clutch bolt remove drive belt use strap wrench hold pulley while you remove fan clutch bolt this procedure for checvrolet if you working on volkswagon you need spanner wrench hold the idler pulley while you use large wrench to loosen the large drive nut to fan clutch. you have to remove fan with clutch from engine then you can remove clutch from fan you can go to auto parts stores rent a spanner wrench try auto zone they rent out tools.
Jan 05, 2012 | Cars & Trucks
How to remove the fan clutch
To remove fan clutch, you need a special clutch fan tool. Sometimes i can remove it with a large adjustable wrench while locking the water pump pulley. Remember to turn counter-clockwise.
Feb 18, 2011 | 1996 Ford Explorer
Im trying to take off the fan behind my raditor. what is the best way to do this? i removed the raditor and need to replace the fan now...
You will need a fan clutch tool or a large adjustable wrench. Some fans have reverse threads (ie: right = loosen, left = tighten) so take a look at the threads on the new fan to make sure your turning the fan the correct way. Keep the serpentine belt on to help stop the water pump from turning. There is a tool to stop the water pump from turning while removing the fan clutch. But usually a large clamp or pry bad used cautiously can do the trick. It wasn't necessary to remove the radiator to replace the fan.
Jul 31, 2010 | 2000 Chevrolet Blazer
How do you remove the fan from the water pump?
after remove the 4 nuts in water pump need to remove a large nut in front of the fan.
on the back of the fan right in front of the pulley is your large nut.. grab the right sized wrench and hold the fan so it doesnt turn and crank on it. it should come off..
**** have a reverse thread**** loose to right
Jun 01, 2010 | 1996 GMC Sonoma
Removing fan on 99 denali ?
Check the rotation of the bolts. My 99 Suburban was reverse threaded. I messed with it for an hour trying the lefty loosie/ righty tighty normal thinking before realizing it was reverse threaded and I needed to turn them to the right to loosen them.
Feb 25, 2010 | GMC Yukon Denali Cars & Trucks
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
How do I remove the fan assembly from the water pump on a 2003 chevy suburban?
You'll need a clutch fan wrench. It's a thin, large open end wrench that is available at most part stores. Place the tool over the large bolt that holds the clutch fan to the water pump and give it a quick hit similating an impact gun. You may have to do this a couple of times, but the clutch fan will come loose and simply unscrew it.
Mar 08, 2009 | 2003 Chevrolet Suburban 1500
2002 Audi A4 Avant, Alternator pulley wheel sheared off.
This is the one on the driver's side right? To remove them on the V6 models (when I've worked on them it's been the previous generation V6 models) I remove the large nut on the fan shaft - it's a reverse-thread so you have to turn it to the right to loosen it. Try that out and see if the fan comes off. I do it that way and haven't had any trouble with them yet.
Nov 05, 2008 | 2002 Audi A4
How do i remove the fan blade from the water pump -= the seal is leaking and i am replacing the seal behind the water pump - but i cannot figure out how to remove the fan blade .
If you go to Auto Zone or some other auto parts store that offer a loan a tool program, you can get a fan clutch removal tool. It looks like a large two prong fork that fits around the small bolts to the pully and a large wrench for the nut on the fan ( between the fan and the pully) should cost about $15.00 and you get that back when you return the tool.
Jun 06, 2008 | 1996 Ford Explorer
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
