The TV was set to the HDMI selection. The screen was a darker blue than the default screen. If I turned off the tuner the TV displayed no signal so it TV knew the tuner was connected.
SOURCE: picture blurry on my Westing house LTV-32w3 HD Television
hi possably is the fan in the back make shour it is working all the time that there is no dust bild up on it stops it from spining it may need a cleen ,or it is a transister heeting up and cooling down the transister is on its way out it will be a hard fix for a tech to fined thay will fined it but it will cost you a heep ,its best to whate till its gon completly .cheers peter
SOURCE: picture quality
same problem with mine i unplugged it for half hour and plugged it back in it works fine now
SOURCE: my westinghouse lcd tv ltv-32w3 hd
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
SOURCE: problems with ltv-32w3 hd
You need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller): http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
You cam see the one I fixed here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
SOURCE: bad color
Chances are it is the connector on the "lvds" cable where it attaches to the lcd controller board. Detach the connector and clean any glue or tape residue off of it with isopropyl alcohol or electronics cleaner and then reattach it.
