SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
SOURCE: Slow coffee stream and smaller brew size with B70
I had the same problem, contacted Keurig and they suggested the descale procedure, which did nothing. The brew size was very small, the display would not let me select the size, and water was being pushed back into the reservoir. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, and when the reservoir was empty of the solution let sit 2 hours while unplugged and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since. This may work for you...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
