How can i correct iconia w510 touch malfunction? showing a bubble stuck in top left, seems to have started at same time as touch problem started. now cannot pull up charms.
I did calibration; touch is sometimes responsive but not fully like it used to be. i'm guessing something downloaded in update and caused a problem; i did troubleshooting but still junk. what to do?
Since you tried to reset the tablet, you can try doing the hard reset. Just to let you know, performing hard reset deletes the data from your tablet. Iconia Tab A200 How to Perfom Hard Reset
Drag down the menu from the top of it. There should be 2 parts of it. Slide top to left. Click rotation if it shows lock. If it shows a phone with 1 or 2 arrows. Then the rotation is free to turn.
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The
following steps will erase all of your personal information, all stored
contacts and any programs you have installed on your tablet. 1.Power off the tablet. 2.Press and hold the Volume up button, which is located closest to the touch screen lock switch. 3.With
the Volume up button held, press and hold the Power button for 3
seconds then release it. Continue holding the Volume up button. 4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button. 5.Release
the Volume up button and stop switching the touch screen lock switch
once the "Erasing Userdata..." message appears in the upper left corner
of the screen. 6.Once the factory reset has been completed your
tablet will load to the Welcome screen. 7.Your Factory Data Reset has
completed now follow the onscreen steps to setup your tablet."
Perform a Factory Data Reset of Acer ICONIA The
contacts and any programs you have installed on your tablet.1.Power off the tablet. 2.Press and hold the Volume up button, which is located closest to the touch screen lock switch. 3.With
Hold the power button in for the count of ten, it should shut it down and cause it to ask you to boot up in safe mood, it may take a couple of tries but it will eventually go to a menu to ask for the boot mode....I recommend spyhunter4...I just removed that virus from a clients pc two days ago
Go to acer.com click on support then download. You next need to select your device to go to its support page. Tablet, then Iconia Tab then W500P then click on image of your tablet. Under DOCUMENT scroll down to find the user manual. You have to scroll down or it doesn't show on the listing. Click on the orange download button at the left of the line listing and the zipped user manual ile will start to download. Your browser will either ask where to save this to or will put it where you have specified under browser options. I you save it to a place you can recall or to your desktop then you can extract the files usually just by clicking on them. Inside will be a pdf file which is your user manual which you will need something like Acrobat reader (free from Adobe) to use to read this file. If the second part of this works that will be the direct link to the user file and you might be able to download it using that.
