No matter how i set the screen it never show the full screen, the sides are cut off
SOURCE: Tv picture not all showing up
this is like the conversion Ic's that is for projection tv's, but different for an lcd or plasma tv , it will need to go to the shop where they can order the board to correct this problem. these boards are not available to the public. you can try to replace any components on the video processing board that are bad , like electrolitic caps , surface mount resistors , diodes , but if it is a surface mount chip then you will need the whole board , because thats the only way to get it
electech
SOURCE: Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
SOURCE: Our TV has only 2/3rds visible. The 1/3rd is black
Y Main board has failed.
Y Main controls vertical lines in the picture. Plasma TVs have x2 of these Boards. One for left and one for right. It sound like one of these has failed. Loose connections may also result in the symptom you reported
SOURCE: I have a 19" Hisense flat screen tv that is LOCKED
software problem , please replace eeprom i.c.
