Will get e mail wont send them
Once you change your hotmail password you then have to change it in TWO different places in your iPhone settings. 1) Settings>Mail, Contacts, Calendars>click on the email Account you changed the password for>under "Incoming Mail Server" change your password>then scroll down a little farther to your Outgoing Mail Server SMTP and tap that>under Primary Server tap smtp.live.com or whatever it says and make sure it's on>then change the password in here as well under Outgoing Mail Server. Now you will be able to send and receive hotmails like before.
Thank goodness you posted your response, seems so easy when you know what you are doing. Woohoo I can now send email again, Thanks
Yay thank you, I was so stuck!
My iphone quit sending emails when I changed my Hotmail password. It would receive them. I fixed this by going to : Settings / mail /accounts (the account you set up) / SMTP / Other STMP servers.
Turn on AT&T SMTP server
You may only have the password in for the incomming mail and not the outgoing mail.
Go to Settings -> Mail, Contacts, Calendars, and select the email account that is giving you trouble. Make sure you have an outgoing server set up, and verify it is going to the correct address. Your email provider can give you this address. Once you've verified this, if it still isn't working, double check to make sure your username/password is correct.
I just fixed my iphone with the outgoing mail problem. I only had the password in for the incomming mail and not the outgoing mail. Once I entered the password for outgoing mail, it worked like a charm.
You have to re-configure your e-mail settings, that is most likely an incorrect setting for sending e-mail.
My galaxy i phone will recieve e mails but will not send i have checkedsettings for bt all correct
Ive had this problem for ages where my iphone will receive emails but not send them. I've tried everything but eventually got it fixed by these guys
http://www.emaileverywhere.co.uk/cannot_send_email_iphone.html
I downloaded the step by step guide to fixing the problem and sorted it straight away. It cost me 2 quid but well worth it.
I hope this help someone else as this was driving me mad!
SOURCE: I synced my iphone with my outlook email, but
Set up an account on iPhone:
From the iPhone Home screen, tap Settings.
Tap “Mail, Contacts, Calendars,” then tap Add Account.
Tap an account type:
Microsoft Exchange
MobileMe
Google email
Yahoo! Mail
AOL
Other
Enter your account information and tap Save.
If its 'other', the iPhone will try to find your settings based on common email servers. If yours is not found, then you'll need your POP3 and SMTP settings. Done correctly, you'll be able to send your emails from your contact list.
SOURCE: my iphone wont make calls, send texts & the 3G isnt working, help
check ur phone settings if your firewall state is on it should be off click call firewall state off,sms firewall state off.try n let me know
SOURCE: My iPhone wont send email. It says the senders
when you type in the smtp address in the email setup don't type in "smtp." just type in "comcast.net". This worked for me although not on a comcast.net account
