Xt912 razor is the mode of Motorola.
If the phone doesn't have sufficient charge it may do this. Try charging over night and then try power it on. If it doesn't work you may want to do an external reset. How do reset my DROID RAZR
Mark
Motorola Support
SOURCE: Motorola Razor -Silent Mode
what you have to do is customize it as silent mode by turn the ringing volume down and turning the sounds off. this can be done in profiles.
please rate me. thank you.
SOURCE: Phone unlock code for motorola razor
Press the menu on the keypad , now the phone should be asking you for the security code hopefully you have not change it from 000000 - default security code
SOURCE: motorola razor asking for passkey to bond with bluetooth headset
default pin for most bluetooth is 0000
SOURCE: reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
unlock code, security code, and lifetime timer:
settings> phone settings>Reset>Reset All Settings
delete data
Caution: This option erases all information you
have entered (including contacts and calendar
entries) and content you have downloaded
(including photos and sounds) stored in your
phone’s memory. After you erase the information,
you can’t recover it.
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
SOURCE: I forgot my security code for a motorola razor v3m. How to fix?
Take the phone back to your service provider and have them reset the code back to the factory oroginal- usually "0000"- which you can later change.
