And on the screen when I turn it on it says,"Load screen image failed,switch to recovery mode?"What do I need to do to fix it,this is my pride and joy. i cant turn on my mp3, as i got the "Load main image failed Switch to Recovery mode" problem. any suggestions what to do?
This will take care of it.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
Press and hold the "record" button while connecting it to your
computer. Keep holding the "record" button until you see the "new
hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Try plugging the player into the computer and formatting it. This will erase the music from the player, but you have a copy of the music on your computer as well. I think this will solve your problem.
Good luck.
when i turn the switch on it says "Load image failed switch to recovery mode" what should i do.
Load main image failed switch to recovery mode
