Just replaced the lamp, reset tm, worked fine for 4 days, now goes black, but have sound, will come back on for few minutes and go off, repeat, etc...
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
SOURCE: My sony sxrd 60 inch has the picture turning off
Replace your Lamp and you should be just Fine. Call Mats 1-800-628-1118 or Look on line Encompass Parts Distr. they will list your Lamp # or Call them 1-800-638-3328 also Look under E-Bay I found my Lamp for 85.00
SOURCE: RESET LAMP HOURS ON SONY KDS-R50XBR1 sxrd tv
Click here to download the user'e guide and go to page #113 to reset the TV to factory settings.
SOURCE: I have a Sony WEGA KDF-E60A20 for 4-5 years. A few
It's the lamp. I do have an article on this in my Tips & Tricks regarding lamps, but replacing the lamp is a sure fix. I hope this was helpful, best wishes.
