Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
OUr LSE7806A has been in storage for a long time, after installing it, the dryer works but the washer will not fill or anything, Help Please!?
Washer will not fill, come on, or anything!
6ya staff
SOURCE:
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
Posted on May 23, 2008
Anonymous
SOURCE: Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Posted on Jul 24, 2008
duby1990
Justin Duby
  • 370 Answers
SOURCE: MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Posted on Nov 21, 2008
Anonymous
  • 1066 Answers
SOURCE: WASHER FILLED WITH WATER AND STOPPED WORKING COMPLETELY
if you hear a motot running the coupling between the motor and transmission has disinagrated.
Posted on Mar 11, 2009
jimorris77
  • 411 Answers
SOURCE: my dryer works but the washer won't work or fill
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 04, 2009
What would stop the washer in our LSE7806A from working?
Let's figure out what it's doing or not doing. From that, we can figure out how to make it do what it's SUPPOSED to do, or stop doing what it's NOT supposed to do.
First... since it was stored, we can pretty safely assume that it was deemed to be suitable for storage - actually functional - when it was put there. Why else would one store it?
So... tell us a little about what happens or doesn't happen. When you plug it in, connect the water, turn on the water, fill the machine with clothing, select a wash cycle, and turn it on... what happens? If NOTHING happens (the machine sits there dumb & silent), check the power outlet to be sure there's good power there. Plug a lamp into the outlet to prove it.
If it hums and clicks but doesn't release any water to fill the tub, doublecheck your water supply. Prove that water does indeed come out of the taps. Also check the little screens in the water connections to the washer - are they clogged full of dirt and sand? Wasp mud nests (from storage)? If all looks well, look closely at the water control solenoids inside the washer. Check power there, verify solenoid operation.
Next... if it fills but doesn't move, doesn't agitate, doesn't spin... check the motor. Verify power there, inspect the drive belt.
If all is well up to this point but it doesn't drain, inspect the belt again and look closely at the pump.
If it makes odd noises, look inside the back or bottom (or remove the top) and determine where those odd noises are coming from. You can track them down by ear (ears are marvelous directional finders for sounds) and hands and eyes.
If you find the absence of power anywhere except in the power cord, look to the washer's control head. Trace power through it (for this a multimeter or AC test light is a handy tool).
Keep us posted on what you're starting with and what you find.
Jul 31, 2014 | Maytag LSE7806A Top Load Stacked...
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
Washer doesn't work and the water doesn't come on.
Check the water valves work, fill then wash, then drain then spin, if it doesn't fill it won't wash
Nov 12, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer not working.
Renee, after you hit your wash cycle selection does the washer begin to fill with water and rotate the wash basket? I need to know what does work , it will tell me what does not. capnhook
Oct 01, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
158 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
