KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
A
Anonymous Posted on Jul 31, 2014
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Steve Sullivan
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Feb 24, 2016
Steve Sullivan
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
7280
Points
13
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 01, 2009
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • Posted on Dec 04, 2009
SOURCE: microwave model KHMS155LSS-3 turns self on
I had the same problem with the same model of KitchenAid Microwave. KitchenAid customer service will act like they never heard of the problem, although if you google it, you will find that this is a very common problem. Ask to be transferred to the safety department. After more than 6 months of complaining and several repair attempts (they replaced control panel and switches), KitchenAid finally gave me a full refund. This is a serious safety defect for which they have no fix. The product needs to be recalled, and I am willing to testify that KitchenAid was criminally negligent when this product finally causes a house fire and possibly serious injury or death.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 08, 2010
SOURCE: I have a F6 error
F6 on these models means that the cook relay on the control circuit board is shorted, and it is cooking anytime the door is closed.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you prefer, you can buy a new circuit board (part number 8169733 for $150.27) from the Pros
here.
They're our favorite supplier.
How to reset clock the clock on my KitchenAid Microwave Convection Oven
Usually push click button than set time and push click button again (some will have you push the "start" button)
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
5helpful
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
2helpful
I have a F6 error on my Kitchenaid microwave, model number KHMS155LSS. I unplugged it for 5 minutes. Nothing changed. I closed the circuit breaker for 5 minutes. Nothing changed. If I plug it in, it...
here.
3helpful
2answers
Kitchen aid microwave is locked
Touch and hold cancel/off button until unlock appears on the display.
3helpful
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
My micro wave stop working f-2 is on screen
Possibly a keypad short or motherboard fault if it is a KitchenAid microwave. Beware if you have a KHMS155LSS model, a Keypad short can and will cause the microwave oven to start on its own. A real stunning defect.
Kitchenaid Microwave went blank
Is there a reset button or something I am not aware of?
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
