Model dx 40 l260a12
SOURCE: Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
SOURCE: Broke a brand new TV screen dynex dx lcd32 09 Does anyone know how to buy a replacement screen
Try ebay look up the model number on there useing advanced search you just might find one.. Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
SOURCE: VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
SOURCE: .I have Dynex 32 lcd.
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
