Unfortunately, I can't help you with this issue, because I don't understand it at all. My eldest daughter installed CCTV cameras at my home because she is afraid of me because I am supposedly already old. But then she also installed smoke detectors and water leaks, she is afraid that I may leave the water not turned off or the stove, so she installed them. And in the application from this Ajax company, I monitor the security of my home and, in principle, this application is clear to me, although I am not very friendly with technology.
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
Shutdown, Switch back monitors and try it now.
Good luck
Mike
SOURCE: New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
SOURCE: after starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
SOURCE: analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
