Splendide 2000S Front Load Washer / Dryer Logo
A
Anonymous Posted on Aug 01, 2014
Splendide washer dryer combo door won't open
Door won't open
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Mar 13, 2008
SOURCE: Splendide 2000S
Go to: repairclinic.com
Anonymous
  • 3 Answers
  • Posted on Jan 28, 2009
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Anonymous
  • Posted on Jun 25, 2010
SOURCE: We have a Splendide WD2100 washer/dryer
I had the same problem and ordered one from Westland Sales. Phone No: 503-655-2563 Ext. 5 for parts. I believe I spoke to a gentleman named Terry. I just received mine today, cost was $52.00 including shipping.
Anonymous
  • Posted on Aug 05, 2010
SOURCE: My motor yacht's Splendide Washer Dryer combo has
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
Anonymous
  • 19 Answers
  • Posted on Oct 24, 2010
SOURCE: We need a new door for the Splendide 2000s washer
For parts go to www.westmorlandsales.com .
Splendide Combo Washer Dryer. I need a drain pump for splended 2000 model WD802M
Question edited for a bit more clarity, correct maker name spelling.
Question moved to model category.
Parts suppliers for this RV Washer Dryer.
https://www.google.com/search?q=splendide+2000+model+wd802m+parts
I found one place that advertised it but out of stock, and it is $189!!
$108 for a Used one!
https://rvappliances.visonerv.com/cgi-bin/md/M320259/s1.pl
I need a door handle for a Splendide Combo washer/dryer. %036552563
I may be able to help as I just removed a washer from a motorhome -- in pieces-- contact me if you'd like Dwight 209-531-6943. - Presently in Calif.
Splendid 2000s washer dryer door won't lock
Possible that the door lock is jammed and needs to be replaced.
please check this link;
Replacing door lock
My motor yacht's Splendide Washer Dryer combo has nerver dryed the clothes
3helpful
Broken plastic door handle
Depends what you mean by the "handle". The outer door ring is listed as a spare part 112100592, and behind it is the "handle"
112300530.
In view of the age of this model, spares may be hard to find, so keep an eye on eBay for a used door or door assembly or whichever of the part numbers above is required. Good luck.
11helpful
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Top Splendide Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ADMIN Andrew
ADMIN Andrew
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
