How do i find a unlock code to unlock my samsung flip phone? Ihad this phone for a while and would like to send it to a relative in another state for use with simple mobile. Im trying to get it unlocked before sending it out. Please help. Thank You
Hi. You can get the accurate unlock code for your Samsung SGH-D407 model mobile phone from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Samsung SGH-D407 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
SOURCE: MobileUnlockGuide.com
SOURCE: phone freeze unlock code
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000#
If your phone says wrong password, turn your phone off and put in an
unaccepted Sim Card into the phone (A sim card from another Service
Provider) and then start the process over again. If it says wrong
password even with the wrong Sim card, then you have reached your
second attempt, Do NOT try it again. Instead, go to Ebay and purchase
an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now
that you know your phone's unlock code, (00000000) you can use the
following codes to unlock individual locks on your phone (Where you see
the word Code you will put in your new unlock code, which is now
00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
SOURCE: Samsung U600- WAP and MMS settings for T-Mobile
I have had a similar problem when I first got my unlocked phone. I have T-mobile as well, and once they find out you have a phone device not purchased by them, they are not very helpful - they will give you their default mms settings(same ones listed on their site). I tried those settings and they did not work on the particular unlocked phone I had. I did some extensive web searching and came across a few settings that worked with my phone. I will list them here. Hope they work for you!
*MMS Settings: Home URL - http://216.155.174.84/servlets/mms
*Protocol Type - WAP
*WAP IP Address - 216.155.165.50
*GPRS Access Point - wap.voicestream.com
*GPRS Username - Leave Blank
*GPRS Password - Leave Blank
*Authentication Type - normal
*T Zones - http://wap.myvoicestream.com
SOURCE: How to unlock security code FROM Samsung SGH -f330 mobile phone
Wayne,
if you have forgotten the security code then the only way is to get the firmware reinstalled. That is the problem with these codes. You end up deleting all the dat that you were wanting to protect.
While, if you want to remove the code then go to Tools->Phone->Security. And then select the option on phone lock. And remove the code from there.
SOURCE: looking for code to unlock samsung mobile phone SGH B100
samsung sgh-b100
i want the code to restart the phone also want basic code plz help me now
SOURCE: unlocking code for diamond twister in samsung corby
Visit www.FreeYourCellphone.com
they can unlock any pone from Fido, Rogers, AT&T, T-Mobile, Verizon, Bell, Telus, Sprint, Wind Mobile and Virgin Mobile(Canada) and more
They are major suppliers for most resellers so there price is good and service is super fast and professional
They can definitely unlock your Samsung Corby
Cheers!
