Question about Apple iPad 2 Wifi 16GB
How do I unlock a disabled ipad 2?
My Ipad 2 says "Disabled Connect to itunes",so I put it in recovery mode and connected and when I try to use restore in itunes it says Extracting data, it takes a while then says Itunes cannot connect to the device. How do I unlock it if I can't restore it thru itunes.
    Top Expert:
  • Apple Master
  • 6,740 Answers
First try to reset the iPad, by pressing both the home button and the on / off button, till the apple logo comes on the screen. Then try again. You should have a password for you Apple account, because that will be asked. If you don't have an account name for the device not worth trying, because it will be blocked anyway.
If this does not work, why not try one in this link?
How to Reset Forgotten Password for an iOS Device
Posted on Aug 02, 2014
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Mar 19, 2017 | Apple iPad Tablets & eReaders
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Aug 30, 2016 | Apple iPad Mini
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
Sep 07, 2014 | Apple iPad (16 GB) WiFi Tablet PC
First generation ipad stuck in recovery mode
See here: https://discussions.apple.com/message/19437802#19437802
Make sure you are using a known good Apple cable and not a third party cable - some third party cables do not work properly. Also make sure iPad is fully charged before starting restore.
Good Luck.
May 23, 2014 | Apple Ipad First Generation 64gb With Wifi...
Ipad is disabled
Erase and restore If you can't remember your passcode, you'll need to erase your device, then use a backup (if you have)to put your data and settings back on your device. -connect the iPad to a computer with installed iTunes software:
iTunes
If you've synced your device before with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter your passcode use recovery mode. (Click the link to be taken to the steps.)
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
ipad-disabled-xxfkevokwfrpmirwnynhydw0-3-0.jpg ipad-disabled-xxfkevokwfrpmirwnynhydw0-3-2.jpg Forgot passcode for your iPhone iPad or iPod touch or your device is...
Mar 09, 2014 | Apple iPad Tablets & eReaders
I Pad has been disabled
If you cannot remember the pass code you will need to restore iPad through iTunes. You must put the iPad in dfu mode to restore, there are several videos on YouTube on how to put your device in dfu mode. After it is I dfu mode, simply plug device into iTunes. iTunes will detect that the device is in recovery mode and give you the option to restore..
Mar 05, 2014 | Apple Ipad2 32GB Wifi
Ipad A1396 is disabled it says to connect itunes but itunes does not connect or recognise it
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
Jan 28, 2014 | Apple iPad 16 GB 3G Tablet PC
Forgot reset password
you can reset your iTunes password from the iTunes web site, and the associated em address. and restore the iOS device on your computer with the iTunes app
Jan 08, 2014 | Apple iPad 16 GB 3G Tablet PC
My ipad2 is in disabled mode, how can I get back into it?
means too many wrong codes
plug in pc and use itunes to restore
Oct 17, 2013 | Apple iPad 2 WiFi 3G Tablet 32 GB 97 IPS...
Forgotten Code
You need to connect it to the computer and reset the device.
-First you need to put it on DFU mode (there a lot of videos on youtube)
-Then connect the device to the computer
-Open iTunes (it will tell you it detected a device on recovery)
-Then select restore factory settings
Done!
May 21, 2013 | Apple iPad 2
Apple iPad 2 Wifi 16GB Logo
328 people viewed this question
Top Apple Tablets & eReaders Experts
 Larry
Larry
john smith
gaucherre
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
