If you look at the instruction under 'search for your codes' it will tell you how to scan all the code until you find the one that will work. Down load the manual here for your remote:
http://www.comcast.com/corporate/customers/customer_support/remotes.html
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
