I bought a foreclosure and dont have a code to get into the system. No lights are on, so I dont know if its just turned off or what.
SOURCE: Don't have the access code
Depending on how option 54 is set the default master codes are 123456, 12345, 1234 or 123. The default Utility codes (1-Dealer, and 2-Installer) are 654321, 54321, 4321 or 321. If you get any of these to work, you can follow these steps to reset the memory to factory defaults:
SOURCE: GE Simon3 Wireless Security system
If your problem ain't fixed and the system is not in the trashcan yet, try this:
Open panel and enter Utility access code (654321 / 54321 / 4321 / 321), mostly it's 4321, unless someone changed the code.
Unplug from powersource and unplug battery.
Now comes the fun part....
Press Cancel + Clock set + Minutes+ at the same time and restore the power with the battery.
If it says "Hello, System XX OK" you've reset the panel to factory settings and can set up the whole system from the beginning.
SOURCE: Installer code doesnt work
you cant reset it once its in an alarm state. but if you can open the front and enter programing with the installer code, you can change the access codes.
SOURCE: GE simon 3 security system How to reset master code?
The default master access code is 1-2-3-4, try it to see if this works.
SOURCE: Hello I have a simon 3 and need to reset the
You can change the master code only if you have the installer code. If you don't have the installer code, the only way I know of to reset the master code is to reset it to factory defaults. This does mean that you will have to completely re-progam the system. I would document as much stuff as you can from the display before resetting it. If you don't have a copy of the installation manual I am providing a link below. Hope this helps.
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
