Question about Ricoh Aficio SP C820DN Laser Printer
Error582 fixed a new fuser unit but error 582
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 417 Answers
SOURCE: sc error 380 and fuser breakdown
Hi there you will need to replace the development motor but first try the following.
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and protected print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
Method 2: Press the “Up/Down arrow” keys together for about 5 seconds, then
press the “Enter” key.
The above message shown in the illustration appears on the display.
NOTE: The machine automatically goes off line when you enter the service mode.
Using the up down arrows select Engine and enter by pressing enter or # key.
Using the up down arrows select mode 5 then enter using enter or # key then select 810 (SC reset) press enter then if you want to select 809 (SC Detection ON/OFF) Enter and select 1 to disable. Escape or return key all the way out and exit. Turn the machine off then on again and test if the same problem then replace the Dev unit if still having the problem then replacement of the motor likely. I can email you the complete service manual if you like.
Thanks J
Posted on Jan 20, 2008
Anonymous
  • 417 Answers
SOURCE: SC380 and fuser unit break down
features
Thanks J
Anonymous
  • 417 Answers
SOURCE: fuser unit breakdown error sc380
features
Thanks J
ricohguy
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
How to reset error sc 582
sc582 is an inverter error. The coil that heats the fuser may be bad, or there may be a bad connection somewhere. If you go into SP mode and execute SP 5810 to reset the fuser, see if the code comes back. If it does, have a Ricoh technician check the IH coil and the connections for it.
Jan 02, 2015 | Ricoh Aficio MP-C4000
Service call 582
This error is a fuser error .
The fuser is not set properly,remove the fuser and set in properly if the problem persists, fix in a brand new fuser.,
If the error appears again then call an expert to check on it for you.
Good luck
Apr 09, 2014 | Ricoh Aficio SP C820DN Laser Printer
Lanier 540c printer
IH inverter current error at power on. Either the fuser is damaged or the invertor coil is defective. You really should have a Ricoh tech look at that one. It is not an easy fix for the layman.
Feb 11, 2014 | Lanier Office Equipment & Supplies
Error fuser unit hl-5350Dn
The fuser unit is located at the rear side of the printer.
Fuser unit error indicates one/more of the following.
1. The fuser roller/film life is over. Replace with new one
2. The fuser film is torn. Replace with new one.
3. Fuser heater is burnt. Replace the heater.
4. Fuser thermal sensor is open. Replace it.
sonsunny
Jun 28, 2011 | Brother HL 5250DN Laser Printer
Solution to solve system Error E007 on IR 2016i copy machine
Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place.
fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon CLC 1140 Copier
Engine fuser low heat error what is it and how do I fix it
Either the lamp or the sensor is bad on the fuser, check www.precisionroller.com for a new fuser.
Oct 29, 2009 | Samsung CLP-500 Laser Printer
Open Heat Error For Dell MPF 1815dn
This sounds like a problem with the fuser unit. I would turn the machine off for about ten minutes, let it cool off and then turn back on. See if that works. If this does not work, you would need a new fuser unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 19, 2009 | Office Equipment & Supplies
Error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
May 28, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
Ricoh Aficio SP C820DN Laser Printer Logo
101 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
