Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Maytag dryer making an electrical humming when turned off, panel lights blinking and humming when turned on
    New Friend:
Test the mother board,
Posted on Aug 04, 2014
3 Suggested Answers
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Maytag LSG7806A stackable washer/dryer - dryer not working
Deb, as long as the ignitor is glowing, it's probably your coils on the valve. Look at number 13 and 14 on the attachment. Part number for the booster coil is 306106 and 306105 for the secondary coil. Not a hard job, the coils slide right off after removing a screw and then replace the harness. Catriver...post back.
Posted on Oct 15, 2006
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: This afternoon, the power to the dryer went out.
It sounds like you either have a defective control board or a bad thermal fuse. To access the thermal fuse you need to remove the top panel, then remove the control panel and then the front panel. The three fuses are attached to the left side of the heater canister. If one doesn't read less than 1 ohm then you need to replace it.
Also, check the voltage coming out of the outlet that the dryer is plugged into using a Multi-Meter. You can also try resetting the breaker controlling the circuit with the dryer. Else, replace the main control board.
Here is the Main Control Board:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-assy-pcb-parts-item-number-ap4045210.aspx
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Aug 11, 2011
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
Kitchenaid blender motor loud hum not working
Can you check it without the beaker on? It could be the blade seizing up, how free does it turn by hand?
Dec 02, 2012 | KitchenAid KSB560 5 Speed Blender
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 11, 2009 | Televison & Video
TV blinked out and now it doesnt come on?
Feb 26, 2009 | Akai LCT2715 27 in. LCD Television
My Intertherm, electric ignition furnace will hum and hum but not click on. There are two yello flashing lights until we reset it by turning off the gas and turning down the thermostat. The unit resets...
That blinking yellow light is an error code. If you look behind the main cover there will be a wiring diagram and error code chart. This will give you an idea what the problem is.
Nov 07, 2008 | Heating & Cooling
Can't make copies
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Sep 10, 2008 | HP Laserjet M1319F Laser Multifunction...
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
