My washing machine will run all the way through it cycle but when it gets to the spin cycle it will just keep draining water what do I do.
SOURCE: simpson swf85561 wont drain, spin or wash goes to end cycle
It sounds like your outlet is clogged. Unplug the Washer first. You need to take off the back, there is a plastic piece attached to the hose where the water comes out. It may look like an enclosed bowl. Items that get sucked in, socks, scarves, etc... tend to get caught into this. If it is supposed to be clear, but it isn't, then there is something stuck in there. You must pull it apart and remove the laundered item.
A way to avoid this happening in the future, if this is the cause, is to put small washable items in the center of the load. Do not overload the washer.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Testimonial: "Hi ours is a front loader it has a filter inside the drum, which you have to align with the drum to get to i have checked that filter it just had lint it is impossible for anything as large as a sock to go further than that filter, i took the hose of the plastic mount and held it lower than the machine & all the water drained, plugged washer back in and started a load it actually filled up with water for about 1 minute then cut off again back to " end load ""
SOURCE: WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
