KitchenAid KT2651X Epicurean Stand Mixer Logo
A
Anonymous Posted on Aug 03, 2014
Does the epicurean have an attachment for ice cream maker?
Michael Maier
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Aug 26, 2014
Michael Maier
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
755
Points
The Model: the Kitchenaid KAICA attachment will work with all Kitchenaid mixers 4.5 to 8 quart models both tilt head and bowl lift.
5 Related Answers
defrankond
CJ C
  • 66 Answers
  • Posted on May 09, 2008
SOURCE: How do I remove the
your not supposed to remove the cap. under that cap is just a gear assembly that powers the beater assembly. some of these attachments are only compatable with certain units. some of the older units arn't compatable with the newer attachments.
Dan Hudson
  • 119 Answers
  • Posted on Nov 30, 2008
SOURCE: how do you attach the
I beleive that you need to have a bowl lift version to use the ice cream maker. Check you owners manual. If you do not have a manual, you can see it online HERE.
David Shaub
  • 2994 Answers
  • Posted on Dec 10, 2009
SOURCE: My Ice cream maker attachment for my Kitchenaid
You must remove the dasher from the holder BEFORE you raise the mixer.  After that, you can remove the adaptor.
John Morganti
  • 864 Answers
  • Posted on Jan 17, 2010
SOURCE: can't attach ice cream maker dasher
If the bolt is the hinge pin that the head swivels on when tilting it up, it can be pushed back in when the head latch is released and the mixer head is lifted slightly.
Anonymous
  • 235 Answers
  • Posted on Feb 23, 2010
SOURCE: I have a kitchenaid 5ksm150(UK), I recently purchased an
Hello KELPIES52. I see you have two postings, with some minor differences. You say purchased an “ice-cream maker attachment” in the US and my first clarification question to you is, did you purchase the KA Ice Cream Maker, Model KICA0W, or some other brand that said it was compatible with KA mixers?
If you did buy a KA ice cream maker, then it should fit all KA models, including yours. If you purchased another brand of ice cream maker, then it may never be truly compatible, and there’s the rub.
First regardless of what brand of ice cream maker you purchased, you should have both your KA mixer’s Parts List manual and both the KA Ice Cream Mixers Parts List and Users Manuals in hand. If you're lacking them, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use 5KSM150, for you mixer and select the file 5KSM150PSEWH4.pdf (777.26 KB) listed under Parts List (1113) (you can actually choose any file sized 777.26 KB; they are all for the different color UK models) and then check to verify this matches your mixer model. This is a good file to have on hand if you ever decide to troubleshoot and fix your mixer by yourself.
After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List and the Use & Care Guide manuals (even if you don’t have a KA ice-cream maker) for your future reference.
If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer's agitator shaft. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
On the other hand, if your ice cream maker is not a KA model, you can still remove the collar, spring and groove pin if you’d like to give it a try. You will need a punch drive with a smaller diameter than the groove pin, a hammer, steady hands and plenty of patience. Tilt your mixer’s head up and rotate the planetary agitator shaft so that the flush end of the pin with the agitator shaft is facing you (the extended part of the pin is facing away from you). Align your punch drive on the end of the groove pin and give it a good whack; repeat until the pin starts to come out the other side of the agitator shaft. Continue tapping until the pin comes completely free. (Note the groves on the pin as you will need to orient the groove pin the same way when you reassemble the spring and collar on the agitator shaft when you’re finished making ice cream). Once the pin is removed the spring and collar will easily come off and then you can attempt to mount the ice cream maker drive on the agitator shaft. Caveat Emptor! Good luck, I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Is kitchen aid ice cream attachment dishwasher safe?
it should be dishwasher safe but just to make sure check the owner's manual it will have that information if it is not in there or you do not have the manual just call the store where you purchased it from
I just bought the ice cream maker attachment and the metal collar on the beater shaft is stopping me from attaching the ice cream maker driver. How do I remove the metal collar from the beater shaft?
You need a small steel hammer and a pin punch. Do not try to drive
out the Groove Pin any other way (i.e. don't force it out with a regular
size hammer and a screwdriver), you will only damage the Planetary plate
and/or the Agitator shaft. Lay your mixer down on the floor and support
the Beater shaft with a wooden block before driving the Groove Pin out.
2helpful
3answers
Have kitchenaid 5ksm150(UK),recently purchased an
After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List manual and then the Use & Care Guide (even if you don’t have a KA ice-cream maker) for your future reference.
If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
Can't attach ice cream maker dasher
I bought a ice cream maker from the US unfortuneatly the drive assembley isn't the right fit for my kitchenaid. Do you or can you help me find the right part? Kind regards Robyn Ricketts
Hi ROBYN, Happy New Year! First a couple of clarification questions: A) Was your ice-cream maker a Kitchenaid (KA) Ice Cream maker, too, and B) was your mixer purchased after 1990? If you purchased a KA Ice Cream maker and your mixer is less than 20 years old, according to KA, the Ice cream maker should fit all mixer produced after 1990.
If you have a different brand (not KA) of ice cream maker, then I’m afraid you just won’t just be able to replace the drive assembly, but you will also need the correct dasher (the scraper inside the freeze bowl), as such you probably would be better off purchasing a KA Ice Cream Maker, which would be compatible with your mixer. Of course if your mixer is over 20 years old, then even if you have a KA Ice Cream maker, it may not fit correctly anyway, which leaves you in a conundrum. Should you purchase a new KA mixer for your KA Ice Cream maker or do you purchase a new KA Ice Cream Maker to go with your current KA mixer produced after 1990?
You can download the KA Ice Cream Maker Use & Care Manual from the KA website at: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KICA0WH_Use%20and%20Care_EN.pdf
I wish I could offer you a better solution to use your new ice cream maker with your current mixer, but unfortunately I am unable to do so.
I hope this was helpful, even if it doesn’t provide you the answer you were looking for. Good Luck, Howard, Burke, VA. If this solution was helpful though, please rate it. hslincoln
How do you attach the ice cream maker to the mixer
How do I remove the metal cap above the whisk? I want to use my new ice cream maker but the attachment won't fit unless I take off the metal cap. I've tried everything but it looks like there's no way of...
2helpful
Attaching icecream maker
KitchenAid Ice Cream Maker Attachment:transp.gif
Convert any KitchenAid stand mixer into an ice cream maker with this handy attachment, and you can make a homemade treat that's fresh and pure. Store the bowl in the freezer, follow directions and you'll soon be making up to two quarts of your favorite frozen dessert. The ice cream maker is designed to fit all KitchenAid household stand mixers.
Includes:
  • Double-walled Bowl
  • Churning Blades
  • Basic Recipes
    Instructions: The freezer bowl must be frozen for 18-24 hours prior to first use. Before each use, bowl must be completely frozen. Cycle time: 30-min. for soft-serve ice cream. For firmer consistency put in freezer for 1-2 additional hours.
  • Not finding what you are looking for?
    Top KitchenAid Food Mixers Experts
    ZJ Limited
    ZJ Limited
    Paul Carew
    Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
