Apple iPhone 4 Black Smartphone Logo
A
Anonymous Posted on Aug 03, 2014
THe iphone could not be restored an unknown error occured 21.
Jesse Allen
Level 3:
Master:
  • Apple Master 307 Answers
  • Posted on Mar 20, 2018
Jesse Allen
Apple Master
Level 3:
Master:
Answers
307
Questions
0
Helped
161098
Points
1872
If you are not using the latest version of iTunes, try updating it to the latest version available first. Here's a more detailed guide on fixing this error: http://www.leawo.org/tutorial/how-to-fix-itunes-error-21.html
Jason Yeaman
Level 2:
Guru:
  • Apple Expert 166 Answers
  • Posted on Aug 07, 2014
Jason Yeaman
Apple Expert
Level 2:
Guru:
Answers
166
Questions
0
Helped
32016
Points
831
Put the device in DFU mode and restore
5 Related Answers
Anonymous
  • Posted on Aug 07, 2008
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Anonymous
  • 33 Answers
  • Posted on Oct 29, 2008
SOURCE: iphone cannot restore with itunes
Try the following links:
http://amountaintop.com/error-1604-when-upgrading-your-iphone-version-1-1-1
http://support.apple.com/kb/TS1458
270rexton
270rexton
  • 782 Answers
  • Posted on May 12, 2009
SOURCE: iphone will not restore
try respring it (central + power buttons together and then connect to iTunes in safe mode,choose full restore (it will erase everything but if you have back up can be restored).
Anonymous
  • 141 Answers
  • Posted on Jan 01, 2011
SOURCE: im getting an unknown error (1611) when i try to
This error may indicate a hardware issue with your device. If the MAC address or the IMEI is the default value (00 499901 064000 0), this can also confirm a hardware issue, to find these go to settings, general & about.
If you can get an appointment in an Apple store they can try a "known good" network connection & connector and try to restore the phone for you but if not it looks like it may be a hardware issue within the phone. If your still withing your warrenty give Apple a ring they'll sort it for you.
Anonymous
  • 17 Answers
  • Posted on Oct 15, 2011
SOURCE: an error occurred while restoring this iphone
You may have the wrong iTunes for that update (you need the newest iTunes in order to restore iPhone's). You might also be installed a outdated iOS, or a higher version than the device you are running can handle.
2answers
THe iphone could not be restored> an unknown error occured 21.
Look this up on youtube. It is a complicated answer but it can be done by following the proper instructions.
tip
Unknown error 9 ipod touch, iphone, itunes
Error 9:
This error occurs when the device unexpectedly drops off of the USB bus and communication stops.
This can occur if the device is manually disconnected during the restore process.
This issue can be resolved by performing USB isolation troubleshooting, using a different USB dock connector cable, trying another USB port, (DO NOT USE HUBS) restoring on another computer, or by eliminating conflicts from third-party security software.
on Apr 15, 2010 • Computers & Internet
1helpful
2answers
Iphone could not be restored an unknown error occurred (-1)
Hi, your i phone has problem in its Eprom either operating system is corrupted or the Eprom chip is damaged needs replacement. take it to a technician for flashing( soft ware re-installation )
Tried restoring iphone on my itunes account and it said "restore failed" my iphone is totally disabled and I am unsure how to fix this problem
When your restore fails, it usually tells you, Your iphone could not be restored, an unknown error occured(number). Get that number and either post it on here or call 800 my iphone with it.
IPhone 3G Unknown Error Occurred 6 can't resotore to 3.0 help
turn the iPhone off, connect the cable to the computer, but do not connect to the iphone. Hold the home button and connect the iPhone to the computer. iTunes will recognize it in recovery mode. (You must have ipsw file) Hold shift and click restore. now look for the ipsw file, choose that file, and itunes will do the rest.
1helpful
Iphone will not restore
Unknown error 1024 on Iphone
add me to your msn and i will talk you through the steps to solve your problem.
add me [email protected]
regards nick
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
