The belkin ultimate keyboard is identified in iPad Bluetooth but it will not connect.
SOURCE: Aloha! i just got a new ipad and would like to
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
SOURCE: I need to send via bluetooth pics and docs to my
You can transfer photoes using "Bluetooth Photo Share" free app. You can download the same from App Store for free. Otheriwse, you may use Camera Kit as well. Let me know if this solution works for you or not.
Bluetooth trasnfer is going to be very slow. The best and speedy way is to sync it with iTunes unless you are transfering photos from another mobile or something.
SOURCE: the icons and keyboard on
if this is within an app, it may be normal as iPhone apps can run in compatibility with the iPad, however certain things will be a bit distorted due to the different screen sizes/resolutions
SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
SOURCE: ipad wont connect to internet
Go to settings and then wifi if it is off switch it on and then select your wifi router and enter your password
