Did you disconnect battery ? bet you did ! you need to reset anti-theft ,disconnect battery again but first open drivers side window all the way and keep keys in your hand (auto locks may lock doors )reconnect battery when lights and horne go off put key in drivers door and turn open lock open lock 3 times that should reset it.
SOURCE: power steering noise
MY SUGGESTION TO YOU IS THAT THERE IS NO REASON TO GO TO THE DEALER FOR SOMETHING LIKE THIS BECAUSE IT WILL COST YOU 3X AS MUCH AS IT WOULD AT A PRIVATE SHOP.THERE ARE CERTAIN THINGS THAT ONLY THE DEALER CAN HANDLE,BUT ANYONE CAN DO THIS ONE.IVE BEEN IN BUSINESS FOR 20 YEARS.
SOURCE: RACK AND PINON DODGE RAM 1500 2005
if you have a leak from the back of the rack your sector shaft seal is defective. to replace it you need to remove the rack and do it on the bench.remove the locking nut and pull the seal from inside.if you are a rooky replace the rack with a rebuild one. good luck.
SOURCE: 1999 dakota rack and pinion leak
You can change the seal, but the new one will most likely leak soon after, the seal starts leaking because of problems in the rack from wear, I would try it but if it leaks soon after replace the rack, they are cheap rebuilt.
SOURCE: 2005 Dodge Grand caravan- After Rack & Pinion
The dummy that did the rack broke your clock spring.
SOURCE: rack and pinion? have play in wheel no sign of leaks new power steering pump installed
Hi Gunny, If your vehicle is fitted with rack and pinion steering also check the rack ends for play. The rack ends are the rods which the tie rod ends screw onto. The other end fits onto the rack of the rack and pinion. To work on those you will need to remove the rubber boots and loosen the locking washer, they can then be loosened with a wrench. If they are worn the play will be evident in the steering. When replacing them also replace the rubber boots. If the boots are worn and road grime and dust enters, you will see leakage from the rack and pinion in the near future. I always thought the Dakota was fitted with a steering box? Regards John
