Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Please remove and then reinstall the cartridges before trying to print again. You might have purchase new cartridges if some appear to be empty. Thank you.
Please double check that your connection to the printer is correct. Also, please check that you're using the correct port as there is a usb and ip port. Thank you.
sc582 is an inverter error. The coil that heats the fuser may be bad, or there may be a bad connection somewhere. If you go into SP mode and execute SP 5810 to reset the fuser, see if the code comes back. If it does, have a Ricoh technician check the IH coil and the connections for it.
