Screen Philips 17 inches LCD doesn't react. Power LED stays off.
Check the tv power supply board,that board where the power a/c cord plug into it.Most common problems on these power supply board are dying and leakages capacitors components parts.Check the power supply board carefully,if u have dying or leakages capacitors parts,these capacitors parts will bulges ups,will not have a flat cylinder heads like the rest of the other capacitors coponents parts.Replaces all these dying and leakages capacitors parts with the same Miro fared and the voltages little higher like 5 to 10 volts higher,the power supply board should not have this problem again.U have all equipments to do basic soldering works and u understand basic electronic wright?Then u should have no problems by replacing all of these dying and leakages capacitors parts that are bulges ups onto it cylinder heads on the power supply board.If u can't do this,tries websites like Shopjimmy.com,eBay.com to by a whole new refurbish power supply board for the replacement.
