Go to SETTING, then select the option RESET device. This will RESET your IPAD to its original settings. It will not DELETE any personal information that you have on it.
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Turn off the tablet and then press the power button and volume down (or - depending on ur device) together until you see the reset screen! If this does not happen turn off and try again!
To download apps for an Android device, you need to have (or create) a Google account - if you have a Gmail account, it is this same account.
Then, you have to search in your tablet apps for the Google Play app and touch on it. Entering Google Play, sign in using your account and you will be ready to download your apps.
NOTE: to enter your Google Play, you will need to have the Internet connection active and correctly set up in your device.
If you have available at your home, try spraying just a little bit of WB40 in the button and try to move it back to its place depressing it and dragging it back with two matches or two toothpicks.
