Question about Tektronix Xerox 016-1829-00 Generic Toner Cartridge Xerox Phaser 850
Can anyone repair a Phaser 850 onsite?
The left hand side of prints are missing about 30mm of ink and I believe it is caused by a thin piece of cardboard that I was using to plug up the paper tray after the plastic piece snapped during use. The problem happened suddenly - not over a period of time and I am missing a piece of cardboard which may have been pushed up somehow, although I can't imagine how. It has been repeatedly cleaned to no effect. Are you, or do you know, someone who is able to fix the machine located near Moorabbin in Melbourne Victoria Australia?
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 208 Answers
SOURCE: Tektronix Phaser 850 Service Fault 13.019.40
Most likely a bad print heat. One of the ink heaters is overheating.
Posted on Dec 07, 2007
Robert Seeley
SOURCE: tektronics phaser 850 - media jam
Exactly what 2 of mine are doing. I have no clue on how to fix this so if you find a solution let me know via e-mail if you can. My e-mail is Seeley4859@gmail.com
Thank You
Posted on Jul 09, 2008
TimeDefensiv
Shahzad Waseem Akbar
  • 746 Answers
SOURCE: Tektronix Phaser 740 model 2740 Errors when
Change its setting with default settings, your issue will be resolve automatically.
Posted on Feb 27, 2011
Your machine is rather old and I suspect that a piece of the cardboard may have damaged the print-head. The age of this machine makes finding parts questionable. I cannot travel from the US to your location, Sorry
Aug 05, 2014 | Xerox Tektronix Phaser 850 Maintenance Kit...
It says paper jam but we do not see any paper anywhere
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
Feb 14, 2011 | HP Officejet Pro 850 InkJet Printer
Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Mar 31, 2009 | Xerox Phaser 850DP Thermal Printer
Phaser Printer 8550 leaves black lines
There is a wiper blade between the print head and the drum. Sounds like you have some buidup on it causing your problem.
Nov 13, 2008 | Xerox Phaser 8550DX Laser Printer
Printing too much too the left hand side.
I had a similar problem with another model. I went on line to the Co. and got all the info I needed.
Apr 25, 2008 | Xerox Phaser 6100/BD Laser Printer
Wrong Color Sticks in printer
I normally suggest running a long wood screw into the ink block to move it back and remove. If it's wedged then gently breaking it and removing or vacuuming the pieces out is your option.
The 07,010.43 code has nothing to do with the ink sticks. Although the result of removing the ink with the printer hot may have caused it.
That code is caused from the print head not moving from home position to the printing position. That print head pivots back and forth on a shaft.
One of 3 things has occured.
1. Ink has spilled into the stainless steel print head block. That block is located on the lower left side of the frame, looking from the front of the machine. The most frequent cause of that code is yellow ink seeping into that block from the machine eing moved while hot.
2. If the machine was unplugged before it was shut down. The Drum wiper assembly may be stuck to the print head, between the drum and print head.
3. One of the cables that run from the print head to the circiut boards that control it, may have shifted and are holding the print head back.
To remove the ink holder where those blocks are, requires removing the right and left side covers, that is held in by some plastic tabs, and 2 electrical connectors.
Jan 15, 2008 | Xerox Phaser 8500N Printer
Code 09,038.46:4776 whats wrong
that code indicates most likely you have an ink stick in crooked, a broken ink stick in or added pieces of an ink stick.
That code is showing that you most likely have an ink stick loaded incorrectly or it broke.
Nov 28, 2007 | Xerox Phaser 8500/DN Printer
Oct 08, 2007 | Tektronix Phaser 860DP Thermal Printer
Piece has fallen out of printer
Yea I had the exact same problem with my Lexmark X1185
Was very lucky I didnt throw out the clear strip thingie before learning what it was :)
Anyways the strip itself passes through a shader sensor located on the rear or the cartridge carrier.( see pic 1 ) .
The second picture shows everything else in close detail Including which side of strip goes where.
Pay attention to the spring (circled in yellow) because i believe it is the cause of the whole problem...The spring end was pulled straight or has too little tension .
Aug 12, 2007 | Lexmark P4350 All-In-One InkJet Printer
Phaser 8200
Not a problem, but turning it off causes the machine to do a setup, which then purges the ink supply and is very wastful.
Mar 21, 2007 | Xerox Phaser 8200 Laser Printer
Tektronix Xerox 016-1829-00 Generic Toner Cartridge Xerox Phaser 850 Logo
27 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
Vincent G
Vincent G
ANTISPAMMER
Vuk B
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
