Could be crankshaft seal or rear main seal
SOURCE: WIRING
Based on this page, front speaker wiring are:
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Changing blinker on 2007 Pontiac G6
It's a monster pain to get to them, but it's doable. Once you empty the trunk, you'll see 4 black knobs - approx 1.5 inches in diameter. You'll need to remove all of these (they just unscrew, but they are plastic, so be careful not to strip the threading) in order to access the rear light assembly.
They're in there snug, but once you find the appropriate sized socket (I wish I could recall well enough to tell you what size, b/c I remember that it WAS an odd size), you'll have to remove all 3 bolts and then push the whole assembly out from inside the trunk.
Once the assembly is out, you will see the rear of the sockets, which simply push and turn to get the lamps out of. As long as you have everything open, I suggest changing ALL of the lamps (brake, tail, and turn signal) on BOTH sides, since the lamp life for all of these is about the same and it's such a pain to get to them in the first place.
SOURCE: 2007 Pontiac G6. Rear license plate bulb socket dead
park lamp and license plate share same fuse.check park lamp fuse.if fuse good you have ground wire problems.
Testimonial: "Thanks for the help! Not sure why the owner's manual doesn't mention that."
SOURCE: my cd player in my 07 pontiac g6 wont play my cds
That usually happens with computer copied discs that are too thick, and are labeled data. You need to use Audio Blanks when you record CD's. Automotive CD players can be a bit more selective when playing owner created discs. If this happens with store bought CD's you may need a CD lens cleaner.
