My Mach Speed Trio Stealth G2 tablet will not hard reset back to factory. What else can I do to reset it?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Testimonial: "I have already tried the Power button and volume. It doesn't work. How do you do the reload the ROM with the flash untility?"
http://forum.xda-developers.com/showthre... But I will highlight that you really do this at your own risk.
SOURCE: i dont have a hdmi on my mach speed trio steath g2 tablet can i hook up to the to watch nexflix
You should look at a Google Chromecast.
This is an HDMI device, that you can stream from your android to the ChromeCast connected to your TV.
They are actually quite cheap to purchase.
Then you use your tablet to control it.
It should also work with Netflix.
