Pf shows a power failure hols the stop clear button and it should work again.As for your other problems I will more details such as a model number Gas or Electric dryer and example of the problem in detail
SOURCE: Maytag neptune dryer won't start
Hey all neptune stricken owners - I removed the circuit board which was darkened substantially in the resistor area, but the maytag repairman got no money this time!! . . . And the cold is no longer the problem it has been for the past couple of years. We replaced the 3 main capacitors(blue) and the cluster of four resistors(brown) - and voila - the dryer works like new!!! It only cost a few bucks ($.67, $.92 etc etc) as opposed to the $151 a new board was going to cost!
SOURCE: Problem with upper cabinent of Maytag Drying Center.
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
SOURCE: Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
SOURCE: how to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
3300uf @ 16V filter capacitor bad on the control board
